Thread: Rear Camera
Old Aug 3, 2020 | 11:17 AM
onehundred80
Default Re: Rear Camera
Originally Posted by vinny1952
Have done a search and found a bunch of stuff on rear cameras, but nothing on how to run the cable, as in, over, under, or thru the bulkhead behind the seats...how has everyone run this cable? also looking at a inside camera, is there any problem with the view considering the angle of the rear window? Thanks
Remove the sill plate, remove the trim holding the matting to the door frame and with the seat forward pull the carpeting on the forward face of the bulkhead away. You will see a runner plug, pull it out and you will see wires going into the trunk, your wires can pass through this hole to the trunk. They can go down the forward face of the bulkhead, under the carpet toward the front. Removal of the similar parts at the front of the door opening and pulling back the carpeting under the passengers feet gets you to the amplifier area and from there you have access to the front of the car.
