Old Aug 3, 2020 | 03:47 PM
GraphiteGhost
Default Re: Expected performance wirh mods
Maybe I am not following this correctly BUT, the SRT-6 is only available in the auto transmission. I haven't seen anything referencing a drivetrain conversion here.
Originally Posted by Diamondo25
> Once you get to where you are HP wise, it's likely that the best mod you could add is a Limited Slip Differential.
Apples and oranges, you posted a reference mentioning something about a 'manual'. Did your post mean a manual transmission? If not, PLEASE explain what you meant here ( ...Do you think the standard is not capable of keeping the wheels straight with so much power on the regular diff?...). Your post 19 referenced, if you misspoke then OK .
