Old Aug 7, 2020 | 04:00 PM
Ronman's Avatar
Ronman
Default Re: BAS ESP warning light
Originally Posted by silenthooves
Just my two pence worth - I had a similar issue the BAS/ESP light came on and off intermittently without affecting any other systems. I screened my car with my Autel scanner, and the live data showed the yaw sensor was showing constant variations in degree angle even though the car was park stationary with the engine off. I replaced the yaw sensor (part number A0025428918 version 01-05) which is located between the gear stick and the handbrake in the cabin. The part was second hand from a Mercedes ML 270 Cdi W163 and cost me £18. Scanning showed no more variations in angle when parked, and the light has been off for the last year or more!
I don't know if I ever thanked you but you helped me about a year ago and told me the correct Autel MD802 to buy and got a good deal on eBay. It was able to read the BAS/ESP module that my MB II couldn't read. Turned out that it was a brake light switch. After replacing the brake light switch then the MB II could read all the modules again, so weird. Thanks for helping me a year ago!
