Thread: Tire fix it
Old Aug 12, 2020 | 08:22 PM
GraphiteGhost
Default Re: Tire fix it
Originally Posted by vinny1952
Anyone have a link, other then a dealer where something close to the original size of the flat repair juice can be purchased? I have a new kit/compressor but it is to tall and will not let the cover lower all the way down, and I love how the original fits into its own little hole. Also, all of my tire sensors are still working, but after 16 years the writing has to be on the wall, new tires will come soon, can the sensors just be replaced with regular valve stems?, and yes, I have downloaded the pdf to turn the light off.... Thanks in advance
/slot
YES, tire stems will fit. You do not have to spend hundreds on an outdated crapola TPMS if you can get away with rewiring the TPMS module with your copy of the .pdf. The dash lamp will still 'self-check' and I don't think any DMV tech will be smart enough to have the time to 'deflate' a tire to see if the system works. There are also 'tech-i' gadgets that will plug into a cig lighter outlet (with screw-on valve stem transmitters) that'll tell you what your pressure situation is within your 4 wheels. I took my TPMS offline long ago, you can too!
