Old Aug 14, 2020 | 06:46 AM
RL67037's Avatar
RL67037
Default Re: 2005 Won’t Start
Originally Posted by CL770
The CAN plug is the one with the Green & White wires, don't plug it in. It doesn't matter if you hook up the ring connector either, but it won't hurt. Make sure you plug in the big connector, it's the power supply to the SKREEM and controls all the door locks.
If you connect the CAN connector by mistake then your car might not start. The signal from the SKREEM to the ECU will be conflicting with the signal from the IMMO delete module.
With the set up you now have it should be possible to mate up multiple key fobs to your car (even if they weren't original to the car). Try it out!
Great information - Thanks!!
I'll report back what happens!!
RL
