Old Aug 14, 2020 | 06:57 AM
RL67037's Avatar
RL67037
Default Re: 2005 Won’t Start
Originally Posted by Viper-666
That sounds very good. Can you please tell me how the procedure is that precision ECU give you to recognize your ECU?
And it where very helpful if you can open the Skreem (the plastic cover) and make a picture of it. I want to understand how they do it. Please share this with us!
And as CL770 also wrote, you can put the skreem back in your car, only connect the big black connector with the mechanical lock. So you can open and close the car with your key fob.
Have Precission ECU open your key fob?
The procedure Precision gave me was to:
Unhook the negative battery cable
Make sure the key is out of the ignition
Connect and install the ECU only (not the SKREEM)
Reconnect the negative battery cable
Insert the key, turn ignition to RUN (not START) and wait at least 90 seconds
Turn the key to OFF and remove the key and wait at least 90 seconds
Insert the key and start the car
I'll try to open the SKREEM and get you a picture, but I think that whatever they did happened in the ECU as there was a tamper proof seal tape on the ECU ... the SKREEM did not have this. I did not have to send my FOB to Precision for this procedure so nothing was modified in the FOB.
