Old Aug 14, 2020 | 06:17 PM
CL770's Avatar
CL770
Default Re: 2005 Won’t Start
Originally Posted by Viper-666
And the sealing of the ECU are useless, because after remove all skews you are able to open the top sheet and use the seal as a hinge. If the seal it on both sides you couldn't open it without destroying a seal
Hi Viper-666
I agree, I don't think they've done anything with the SKREEM. I think they've just installed an IMMO emulator in the ECU. I see that the "Julie" emulator now supports the Bosch ME28 & ME28.1 ECUs. I think it's what they've used.
I've attached a copy of the install instructions.
File Type: pdf
