Old Aug 16, 2020 | 01:21 PM
onehundred80
Default Re: Driver side brake light go off when apply brakes
Originally Posted by Yvonne
The same problem of driver side brake light goes off when I apply brakes with car lights turned on but works perfect when car lights are off.!!! But the “light out” dash light comes on every time I apply brakes regardless!!!! Please help me someone. Sincere appreciation, Yvonne
The dash light probably comes on because the third brake light is not working.
What is the bulb number you have in the two brake light sockets?
Edit
You replied that you were using Sylvania #7528 - 21/5W, however on the blister pack it says 25/6W, this seems OK with the following PDF CLICK
You say
driver side brake light goes off when I apply brakes with car lights turned on but works perfectly when car lights are off.
In the past, people have had trouble when a broken bulb filament falls onto the other filament, could that be your troubles?
