Old Aug 19, 2020 | 09:10 AM
Bigtoyz's Avatar
Bigtoyz
Default Re: 04 hard shift, dash is lit up
Thats what I was wondering, especially with the code 2310- controller network communication w traction system malfunction. Something isnt communicating. I feel totally on my own after the dealership charged $200 to scan it, told me what I already knew, and gave me the impression we would start replacing parts until we solved it. I read that a used one, with all the matching numbers can be swapped in, turn the key on for 1 minute for it to recalibrate to my VIN, and it should work without reprogramming? Any experience with that? I also read a MB article that certain radiators would leak coolant into the trans lines and that would result in harsh shift in and out of gear. Remedy: replace trans, trans lines, and radiator. I recently replaced the original trans fluid with the conductor plate and did not notice anything unusual but..... Anyone ever seen that in the crossfire? This thing has 32K miles! Im starting to have second thought about how bad I want the car. I will be moving it soon and plan to have the RCM resoldered and try to locate a used, correct # BCM to try. With the correct # used BCM, It shouldnt cause any problems that arent reversable by putting the original back in is there? Thank you for the suggestion.
