Old Aug 29, 2020 | 09:05 PM
James1549
Default Re: Remove windshield wipers
Most wiper arms have a small hole near the pivot. Raise the arm, insert the largest drill bit that fit the hole, then let the arm rest. With tension off of the mounting, removal is easier. Also a battery terminal remover will work just as well as a small gear puller.
James
