tadmaz
I've heard from others that your fob won't work after a skreem delete from precision ecu.
That is not true. Mine works just fine. Precision did tell me that if it doesn't work after reconnecting the SKREEM, you would have to re-synch it to the car. I did not have to do that as it worked right off the bat. I do not have the CAN bus wires nor the halo wires hooked up - only the large top connector is hooked up, so I don't believe the ignition halo has anything to do with it. Keep trying to re-synch your FOB.
