Old Sep 13, 2020 | 01:46 AM
JSK's Avatar
JSK
Default Re: Need NEW NOS/OEM Driver's Side Door Ledge/sill Window Seal Strip!
Easy install. Just make sure it’s where you want it when you start it into the retainer, if you try to reposition it it gets all f’d out of shape. I had the old one off and on a couple times trying to fix it. No need to remove the door card. I plan to go back and see if I can insert a piece of Rubber or soft hose into the joint between the new moulding and the door gasket.
