Old Sep 13, 2020 | 09:30 PM
KnightRyder_77's Avatar
KnightRyder_77
Banned
Default Re: Plz help i have put all new parts in.
Originally Posted by Speedy4x4
Pressure plate is not releasing the clutch disc.
Guessing if you try and start in gear with, tires spin with clutch in ?
So as of now Its the same when car is running wont go in gear, and when its not running goes in gear. When its running I attempt to put in 1st gear and car wants to move forward. If I start in gear car want to take off.
So i have at this point took dash underneath and checked the CLutch MC and no leaks, and then cracked open a line on brake cylinder till it was clear. Then I Had my boy pump the clutch for about 10 min. And got back under and turned the bleeder and fluid came out much faster at least and still air, did the same thing over and over still air.
So at this point I ordered a motive product pressurized bleeder from FCP Auto and I am hoping once pumped up to 15 PSI and hope it pushes out all the air. The clutch has stayed nice and tight the entire time.
I know the SC is working i can hear it and I felt it through the hole going in and out.
So thoughts sorry so long.
