ZERACER
Now if someone can only figure out a way to bypass those pesky top sensors that break.
That's easy, just connect the 2 leads together on both sensors.
WARNING !!!!!
If you do this, :
1. Do NOT press the down switch with the header latched.
2. Do NOT press the down switch with the divider in the stowed position and something in the trunk higher than it would be in the top down position.
