Old Oct 7, 2020 | 04:52 PM
thickey892's Avatar
thickey892
Default Re: Starts only on second try but has more issues
Still looking for help on this one, basically iv replaced the following parts
-fan control module
- pulses control module
- RCM
- car battery twice
The car sat at my mechanics for little over a month trying to track down the problem and still no solution.
​​​​​​My main issue is the battery drain. If the car is not started every day it dies and I jump it drive it around/ let it run for a few hours to get a bit of a charge, then the cycle starts over. Iv started just unplugging the battery at this point. Iv read wires and we don't see where the power is being pulled from. Or what's not turning off.
The A/C will not engage untill the car has been ran for about an hour and the car like magic acts perfect sometimes 10 mins or sometimes till I turn the car off. Then it start over.
Do you think this is a body control module issue? I have an 2007 have read the bcm is not self learning for this year?
I'm at a loss at this point. BCM or ECU are the only two things I haven't touched but I don't have the equipment to program eaither one. Any help I would much appreciate!!!
