Old Oct 11, 2020 | 03:23 PM
zip439's Avatar
zip439
Default Re: Low Coolant Light/When Fan turned on weird motor noise
Use Zerex 50/50 pre-mixed anti freeze and bring the coolant level up to about 3/4 to a 1/2 inch of the black reservoir top when viewed from the side. You can see the liquid level thru the white colored plastic. You can also look down through the fill top and see a whit plastic rib in the rear of the reservoir. The top of the rib should remain visible above the coolant level.
