Old Oct 22, 2020 | 02:43 PM
GraphiteGhost
Default Re: AMG Rims on a SRT-6 Staggered But . . .1 thing
Originally Posted by VintageBikesUSA
So I have been looking for some OEM rims to run on my SRT-6 coupe for a different look for cheap and found some AMG staggered rims that would be great BUT they are 18" and the seller is saying he thinks the rear caliper will hit and they will not work. offset is perfect and they are cheap but I cant run spacers because the rears are already 45+ . Can you run 18" on all corners or do you have to have the 19" to clear?
Stock rims guy myself BUT... Trying to find out if a certain rim set will fit needs a lot more research from the manufacturer of your specific style rims (compare dimensions from said manufacturer). Anything else would be guesswork and you may be stuck with rims you cannot use. Find the rims (wheels) model numbers and then find out if they have a 'fitment' chart/tool. Best I can offer, good luck!
