Old Oct 24, 2020 | 01:00 PM
Ronman's Avatar
Ronman
Default Re: drivers side headlight
It is possible to put some solder inside the headlight contacts for the turn signal socket. There is probably a hole there on one of the contacts. You can put a small mirror inside and see the hole. You will need to put a piece of wire in the hole so the solder will harden in place. Then use some light sand paper to shine it up afterwards. You will have to remove the headlight to work on it.
