bruce001
Is this a difficult procedure to change it out?
Any guide to do same?
Fairly straight forward, I followed a couple guys on youtube absolutely destroying their steering wheel to figure out how to take it apart... The only thing I couldn't find was how to take apart the plastic housing after the removal of the wheel and airbag... Just remember to take pictures of parts before removal and mark the column when everything is pulled apart... You will need to make a few cuts to the zip ties holding the wiring for steering to gain access to clips.. also you will need the whole panel below the footwell to unclip harness for turn signal switch
Followed this https://www.crossfireforum.org/forum/interior/51876-procedure-removing-steering-wheel.html
