Thread: Highbeam issue
Old Oct 28, 2020 | 02:19 PM
GraphiteGhost
Default Re: Highbeam issue
Originally Posted by Mauler
Fairly straight forward, I followed a couple guys on youtube absolutely destroying their steering wheel to figure out how to take it apart... The only thing I couldn't find was how to take apart the plastic housing after the removal of the wheel and airbag... Just remember to take pictures of parts before removal and mark the column when everything is pulled apart... You will need to make a few cuts to the zip ties holding the wiring for steering to gain access to clips.. also you will need the whole panel below the footwell to unclip harness for turn signal switch
Followed this https://www.crossfireforum.org/forum...ing-wheel.html
Don't know much about the one wire that is obviously 'pinched', but if anyone finds a wire like that they should put some electrical tape on it. BTW, aren't our airbags two stage? It only looks like two wires going to that airbag connector (unless they use the grounding system for a third wire?). Maybe the steering wheel airbag is not a two stage then? Anyone?…
