No,
This is the pump I replaced. It's the primary water pump:
https://www.needswings.com/water-pump-32amg. I bought it from Rob at Needs Wings too and it's working great as my other one was leaking and the bearing in the center was shot as it was the original.
So there are three total pumps here... You have the primary water pump which I replaced, you have the secondary water pump which I think I need to replace regarding the A/C not working correctly and now this IC pump which I thought was for water but it's for intercooler fluid I take it? I see this here:
https://www.needswings.com/bosch-int...fluid-pump-010 and this verbiage:
"This is the UPDATED BOSCH Intercooler Fluid Pump for use on the supercharged m112 and m113 motors.
When the OEM outdated failure prone pumps die, they stop pumping the intercooler fluid, which in turn increases the air intake temperature past the threshold at which the ECU turns off the supercharger to prevent damage. Your car will then continue to drive (without any check engine light) like it lost half of it's power as the supercharger is no longer turned on. This can be verified by watching your air intake temperature on an obd2 scanner.
These UPDATED Intercooler Fluid Pumps do an excellent job! There is no need to try to use a boat bilge pump in our opinion which will create unwanted pressure and stress onto the expensive intercooler burried in the "V" of your motor. This is the pump we run on our personal cars! New Clamps Included.
We also carry the Optional Repair Harness for this pump (Factory Connector). Not required unless your OEM harness has been modified or damaged."
I'm at work and my car is in the garage at home right now but I'm going to see which IC pump I have on the car now and I'll report back later today.
Assuming I replace the pump what other fluids do I need to buy for that system?
Sorry I'm only smart enough to be very dangerous lol.
