Old Nov 2, 2020 | 11:34 AM
onehundred80
Default Re: Console top plate mount for Conv.
Originally Posted by hemi135
What I need here is, the under-mount plate for the conv. top "switch" plate. It's just glued on from the factory to the console top trim. Once the tabs break, you're screwed. The first three pictures are from an overseas seller on eBay and I'm wondering if there is anyone here that might have one that isn't cracked and is usable. Obviously, the last photo is mine and the tabs are cracked from an aggressive previous owner pushing down on it like a mad man and snapped the tabs. They even tried to put a screw in the side of the tabs to hold in place too, probably shorting out the switch which is probably another reason why my top doesn't function....yeah, I'm still working on finding the cause...What you have out there before I have to buy this one from Great Britain and get it around New Year's Day
That plate is also on the coupes bezel. It is not easy to take off as it is basically welded on, the one from the UK was mounted poorly.
You would be better of getting a whole new bezel for a roadster and save yourself the agro.
