g3air
I have the stabilizer replacement on order. I have the 16mm socket etc required. But what I am unsure about is how to safely "jack up the car". Yes, I am a noob about that. I am guessing I will have to buy or find some additional device(s) to accomplish this.
You do have the OEM jack under the rear rug, don't you? I believe you should be able to jack one side up (front) and get at the thing from there (not sure what side for best access, use your own judgement). Level ground, and wedges under the rear tires and you should be all set (with the tools and part that is). Have fun!
