Old Nov 6, 2020 | 05:58 PM
CL770's Avatar
CL770
Default Re: Car not starting - fuel pump relay
It's the protective cover/heat shield for the crank position sensor. It's held on by two of the bellhousing bolts. I wouldn't worry about putting it back on as I think you're better off putting some proper heat shield material around the top of the crank position sensor.
