mhajek18
I am using a 74 MM throttle body with a needswing MAF Elbow with the OEM MAF Sensor.
Did you replace (or set correctly) the 'O' ring at the intake/Throttle body? If not in its 'slot', you will have a vac leak and erratic idle.
