Old Nov 17, 2020 | 02:45 PM
GraphiteGhost
Default Re: Central locking won't work and lost all interior lighting
Originally Posted by fjcap1028
On my 2008 fuse 9 is for the control unit air bag. Fuse 13 is for roof light,horn,alarm,trunk light and tire pressure. Both are ok. I keep seeing articles about the central locking pump located in the trunk?
IF it hasn't been submerged in water yet (or the other module there as well), poke a hole in both of those rubber (factory) plugs rearward of the axle/diff where a "trunk" would be. That lower cavity below the rug under the Styrofoam is one of the most often happenings with flooding when a leak starts. Poking a hole in them rubber plugs drains any water before it gets high enough to soak the electronics/pneumatics located there. Good luck!
