Old Nov 18, 2020 | 12:53 PM
  #95 (permalink)
zip439's Avatar
zip439
Default Re: (1st Post) Bought 2007 Crossfire
Let me try this cut and past, Directly from the service manual;CAUTION: Do not turn the wheel hub while taking the measurement.
7. Adjust the wheel bearing end play by turning the hub nut (4) in stages while pushing and pulling the rotor firmly back and forth. Adjust end play to 0.01–0.02 mm.
  1. Tighten the hub nut bolt to 11 N·m (8 ft. lbs.) and recheck the wheel bearing end play.
  2. Remove the dial indicator.
10. Install the wheel hub dust cap (2).
11. Remove the wheel bolt from the rotor.
12. Install the front wheel and tire assembly.
