Re: battery drain
Thank you for your input. The battery has a full charge, cables intact no corrosion, etc. There definitely is a drain on the battery when the car is off. We have checked lights to make sure there are not any on when the key is out of the ignition and did not find any. We pulled each fuse individually, hoping it would be an easy fix, but no, there was still a draw on the battery for each one.
Our next thought was the alternator. I will take your suggestion and visit a couple of auto businesses to have the alternator checked.
Thank you.
Cathy
