Old Dec 8, 2020 | 04:46 PM
71cuda's Avatar
71cuda
Default Re: My car is haunted!
The battery is roughly 13 months old. I will try throwing it on the trickle charger. The car runs great with no issues after the incident it's just weird and can't figure out what is causing the issue. When I bought the car in 2016 we traveled 5 hours to pick it up in Rolla Missouri. The car has 120,xxx miles never had issues with it except for having to change the conductor plate and once every so often I will turn the key and nothing will happen, but on the second or third try it Gore's right up. I replaced the rcm with one from needs wings, also replaced the crank sensor with the bosch and can sensor. I also changed the the ignition switch last year but the car had already done the random starting up with not key twice. I also bought a new key through needs wings, but that was four years ago. I wanted to repair or replace the skreem modual and skreem antenna, but there is very little information out there about the skreem module and what fails on them or how to repair or replace anything within the module. Thanks to the whole fca discontinuing the module and not be able to use Mercedes modules it made the price ridiculously high and left crossfire owners not many options.
