Old Dec 13, 2020 | 09:38 AM
  #7040 (permalink)
rbracy10406's Avatar
rbracy10406
Originally Posted by UrbanE
This looks really good
Where are the imperfections? High points?
What’s the hardest step in the process
scale of 1-10?
1= easy
10= don’t try this at home
Thanks! it makes me feel better if you can't see them that easy 😁
There are two tiny black spots where the dip film ripped when I was rinsing it. One below the passenger window button and one at the top part of thr AC controls. Everything came out nice and smooth with no high points because I used heavy coats of the clear coat.
I would give this a 4. Its not too difficult but you have to make sure you are in a well ventilated area. I was using a paint booth with the fans on max and a mask and the 2k clear coat fumes still got to me some. You don't want to breathe that stuff in.
I would say the hardest part is thr actual dipping when I was doing the bigger items. You just want to make sure you are on a 30ish degree angle and take your time when dipping it in the tank.
