Re: OBD11 scanner for SRT-6 needed
I inquired on Amazon about using the Blue Driver LSB2 for my 2005 Crossfire. Following is their detailed response. How many of these functions will our limited ECU actually handle? Please comment. I would like some clarity on the O2 items. If you would email me, I will edit the additional information in.
"Hi! Your vehicle will support all standard features:
- Reading/clearing engine & emissions codes (anything that turns on the check engine light)
- Live Data (you can check supported datapoints in our FAQ)
- Smog Check
- Mode 6
- MIL Status And will display the following live data:
- Fuel System Status
- Calculated Engine Load Value
- Engine Coolant Temperature
- Short Term Fuel % Trim
- Bank 1 - Long Term Fuel % Trim
- Bank 1 - Short Term Fuel % Trim
- Bank 2 - Long Term Fuel % Trim
- Bank 2 - Intake Manifold Absolute Pressure
- Engine RPM - Vehicle Speed
- Timing Advance for Number1 cylinder
- Intake Air Temperature
- Mass Air Flow Rate
- Absolute Throttle Position
- Commanded 2nd Air Status
- O2 B1S1
- O2 B1S2
- O2 B2S1 / B3S1
- O2 B2S2 / B3S2
- Distance Traveled While MIL is Activated"
Reason: Clarity
