Old Dec 16, 2020 | 12:44 PM
Robertwav1's Avatar
Robertwav1
Default Hatch lift supports and Alarm batteries.
Just wanted to post the part# for Monroe lift supports for the hatch. 900118, rock auto, around $35.00 for the set, 2004. Overall length of the lift arm is just over 16" in case you want a different brand. I believe the part # is more important as the generic arms are rated by weight of each arm. I use to install a lot of these on different equipment and they were rated at 80lbs, 100lbs, 120lbs etc.
Also replaced the batteries in the alarm module about 6 months ago but stopped working. Replaced fob batteries but still nothing. My car sits covered a lot under a carport, don't use it much. You think batteries went bad again on the module? I have to check fuses and I will do this as soon as the rain stops. Any input on the module batteries as being the culprit? Thanks!
