amx1397
If they are no good let me know ,I'll take then off the list .
the tranny to shift better (no exturnal adj.)you ,,,,need valve body,,,,,, blure top sensors and tuned tcu , text matt on that list he knows more than I he and Rudy built my trans for the V8 set it up for 1000 hp so i would never have a problem, my first V8 tranny (same as crossfire) (different set od blue tops valve body is the pnly differance) ran over 900 runs down the drag strip with 600 hp engine with no failure
as for alignment ,, get the mercedes adj bolts then get a livetime at firestone I think around $190.00
https://www.ebay.com/itm/Front-Cambe...Cclp%3A2334524
Wow! Drage strip car fun. At 73 I just want a smoth depedable ride. The 1st to 2nd is not a problem just different from smoothness of other gears. As far as front end goes I'll wait foe my new shoxks to arrive. Might be as sinple as new shoxks and correct tire pressure. Pressure ia 35 front and rear. When I bought car they at 50psi. Asked why and said thats what on the side of tire.
