Re: SRT6 No Start
the starter relay clicking is a low battery
the throttle body clicking is it calibrating due to you leaving it on the on position without the engine running, normal
if you disconnect the negative battery terminal and wait 30 minutes and then reassemble and try the key again, does it crank?
