Old Jan 4, 2021 | 07:37 AM
Romad's Avatar
Romad
Default Re: No luck but bad luck! Starting problem.
Tried it again this morning and it started right up with my daily use key. Yesterday I was using my spare key, which had been working fine, but caused the no start problem. The batteries are new in the spare key. When trying the spare key this morning it would crank and then turned right off. Tried several times the daily use key and starts every time. Reason for using spare key was because I had to glue loop on top of fob and glue was drying.
Several days ago I replaced the spare key fob housing because the loop was broken off at the top. That being said it worked fine after changing the housing.
