Romad
"Several days ago I replaced the spare key fob housing because the loop was broken off at the top. That being said it worked fine after changing the housing."
You did move the little chip inside the FOB to the new case, didn't you? I know you mentioned it worked fine afterwards but 'working fine' may just be the lock/unlock function which doesn't use that little chip.
