Old Jan 4, 2021 | 02:38 PM
Romad's Avatar
Romad
Default Re: No luck but bad luck! Starting problem.
You should not be so sure - he is talking about the RFID chip. If you did not move the chip to the new FOB, then engine will start and die twice, then you get a no crank.
This is a built-in feature to tell you (or the guy at the dealership) that the SKREEM is not allowing the ECU to start.
All the circuit board/battery combo does, is operate the lock/unlock function - but George already told you that.
If you are going to ignore veteran member's input, you make it impossible to help you.
ok. So what little chip where? I'm guessing it's not located on the circuit board. A little more explanation woyl be helpfull or even a picture.
