Old Jan 5, 2021 | 10:52 AM
zip439's Avatar
zip439
Default Re: Electrical Gremlins. Need help!
You may have a problem with either the Crankshaft Position Sensor, or the Camshaft Position Sensor. I would also check the main ground wires: a)negative battery cable to fender, b) just forward of battery there is a post with four brown wires, c)under the car on the drivers side bare wire from chassis to engine, and I would be certain all the connections are clean in the main feed fuse box just forward of the battery in the small box about the size of a cigarette pack. Being in NJ I would put a little carbon black on all those connections to insure good connections considering salty roads. Some people have had problems with the connectors making good contact on top the RCM Really Control Module which you have replaced. Good Luck.
