Old Jan 16, 2021 | 05:13 PM
onehundred80
Default Re: Looking for drivers side (UK) front bumper indicator
It is as clear as this question DOES THE UK REQUIRE A SECOND FLASHABLE AMBER LAMP ON THE SIDE OF THE CROSSFIRES as turn signal lamps? There are the MARKER lamps in the front lower fender in our crossfires. No one has said it flashes. One said it can be modded to flash (not what I asked). Our US models do not flash, they are MARKER lights and do not work as TURN SIGNALS. I know the turn signals are in the headlight assembly top (almost center) and they are amber, and they flash when commanded for a turn (or 4 way flashers). I have seen many other cars (not crossfires) that have a SIDE mounted additional flashing turn signal in European vehicles. Two distinct questions about one subject. IS the side mounted marker lamp in the UK crossfires (clear lens and amber bulb) also required to flash like a turn signal lamp. IF NOT, is there a requirement to have a second set of turn signal lamps on a UK crossfire side FENDER. I cannot make it any clearer, so if you don't get it yet, then forget it.
You sure can muddy the waters, UK Crossfires have one side marker per front side, it is clear and flashes orange when signalling and is just orange when the lights are on.
European cars are probably similar as they had to conform to EEC regulations. Flush side markers like ours may not be acceptable.
Crossfires intended for northern states and Canada had block heaters as standard equipment.
Not what you asked but a little more knowledge helps.
