Sussudio
Here’s pictures of the fitment, sorry it’s a little late. I destroyed the bottom part of the actual lighter holder. The person who had it before me glues the damn sleeve in there. If any one has one they’re willing to sell, give or trade for anything let me know please. Thank you in advance. Ali did knock it of the park with this design. I know people are weary about the airbag light but that wasn’t a deal breaker for me. I’ve thought about drilling a hole for it eventually but it’s not top priority yet.
I was going to check in with you guys over here that did it and ask what the circumference of the hole was for that air bag light? Any help would be appreciated
No rush though
You need the diameter of the airbag light hole, not the circumference, it also needs an area into which the light slides and is clamped to. Or you can cut the original hole area out and cement it in place, as this needs to be blended into the existing surface this is a lot of work, UrbanE did it this way.
I just drilled a hole and added the clamp area on the back face.
Both methods require repainting to a more or lesser degree around the hole.
You could fit the AB light into a finished clamp ring with a raised ring that sits above the bezel surface and hides the drilling mark. I used one of those step drills to cut through the bezel.
