Delayed Shifting from stop position
I have a 2005 NA coupe automatic with 86K miles and for the past year the transmission shifts differently at times. From at a stop light or just starting out, the engine revs high before shifting into 2nd gear. Now 2nd to 3rd and to 4th are perfectly fine, just from 1st to 2nd. Then there are times when the car acts normal and shifts fine between those gears without high revving. Has anyone has this issue before and what was the fix? Is it the conductor plate or transmission filter clogged? Fluid is at correct level and not see any leaks from the connector area. I have not experienced the infamous Limp Mode yet. Any thoughts would be greatly appreciated.
