Stevebarb456
no codes - scanned it yesterday
just went back through my notes .......
car would not lock / unlock for wifey- then it would not start at times - i found the anti theft module and door locking vacuum pump sitting in water in the trunk ( trunk must of been leaking)
Replaced both items with used parts - car started and ran well
started acting up again and found the leak was not fixed and water was back in the trunk and corrosion was there
replaced them again and still will crank three times no start and would not crank without disconnecting and reconnecting battery - then the same thing happens
did notice yesterday when hitting the unlock lock button - very slow moving and pump runs a bit longer then usual
just wondering if i should replace anti theft module one more time before sending skreem and ecu out
any suggestions >?
