Old Jan 26, 2021 | 05:28 PM
zip439's Avatar
zip439
Default Re: Looking for Crank Pulley / Harmonic Balancer
Originally Posted by Masko149
I am going to replace the crankshaft pulley, but a bit confused whether I need to replace the front seal as well or not. Because some people say it is better to replace the front seal as you are loosening the bolt and taking the pulley off just in case to avoid this in the future, while some say don’t touch it if it’s good.
You can't get to the seal by simply removing the harmonic balancer; the front casing must come off. If you just need a harmonic balancer, just replace that, and don't go cheap. I bought one from Germany just last month for an M113 for $80 which was a waste of money and time. Your best supplier will be needswings. and you will need the right tools. i bought a 40" 3/4 inch breaker bar to torque the new one on.
