Old Jan 30, 2021 | 11:58 AM
onehundred80
Default Re: Looking for Crank Pulley / Harmonic Balancer
Originally Posted by Masko149
Thank you, that’s good to know, because I was thinking that I will have an easy access to the seal after I remove a harmonic balancer. I am going to buy an updated crank pulley ($400) from the needswings plus a holding tool which is about $75 from the needswings too, that probably should work well. I am not sure if it’s ok to use any cheaper holding tool, please let me know. And to torque the new one I am going use my torque wrench with extender, I think it should work, because so far it is hard to imagine how to turn additional 90 degree after 148lb/ft.
Do not use an extender on a torque wrench it will probably wreck it, use a breaker bar.
