Thread: rear end ratio
Old Sep 13, 2006 | 06:37 PM
stryfox's Avatar
stryfox
Default Re: rear end ratio
I have looked into this about a year ago...no luck.
Berg werks use to make gears for the slk but the went under.
HDDP did some serious searching also and the best solution was to have a set made which i believe was around $3,000 and that does not address any computer problems that may arise from the swap.
Good luck and post if you learn any new info as I WANT GEARS!
Thanks.
