Romad
Went to the store this morning and discovered the left turn signal indicator light quit working. The right turn signal indicator light works fine as well as all the turn signal lights work. Is there a bulb that can be replaced in dash and if so how do you get at it? Thanks
Just to confirm your left turn signal indicator does not light up at all on cluster? Does it still make any noise? You confirmed your left turn signals in the headlight and tail light both blink on the left side?
It is unusual for those bulbs to go bad. There are three bulbs on the back of the cluster for the turn signals. It is not an easy job to take apart the dash and it is hard to remove the cluster bezel and sometimes when you put it back you will have a rattle or two. Usually one the two wedge type bulbs in the cluster burn out first.
Make sure it is the bulbs instead of the actual turn signal on the side of the steering wheel, turn signal socket in the headlight, etc.
If you are sure and want to go this route then it is best you change all the bulbs in the cluster while it is apart. You will need 24 of the 2452MFX6 of and 2 of 0015445594. These are cheap at Autohaus.com.
