Fla_Xfire_SRT
~ What's the trick to REMOVING the pcv valve cover? I removed all 6 screws, disconnected the 2 hoses, cleaned excess factory RTV from around the edges of the cover and she won't budge. The source of the leak was the filler neck and they are difficult to find. The cap had a crack as well. Can't sell a leaky smoker now can we? Any suggestions ..or pictures of where to pry..will be appreciated.
Please do not pry at anything, if you use excessive force you may deform the cover and make things worse. Can I ask, is it hot or cold were you are? I ran the engine before starting to work on my leak, hence the RTV/sealant went soft and just peeled away when I applied a slight rocking pressure from left to right. Once the edge above the spark plugs same away I gently ran a plastic/nylon credit card along the edge to in essence "cut" the bond between the RTV/sealant. Always watch to ensure no "bits" of sealant go into the oilways.
