Old Mar 16, 2021 | 05:57 PM
onehundred80
Default Re: poboys improved cold air intake
Did you put the original MAF sensor into the 75mm MAF after taking out the 75mm sensor? You should use the original MAF sensor, it works just fine. The 75mm sensor causes problems like you have.
You could also have an air leak somewhere.
