Re: News article on switching to Regular gasoline
Napasanaoma is correct; what little saving you'll notice at the pump will be lost in efficiency. Considering our car gets low 30's on the interstate, well it does when my wife drives it, or mid to high 20's when I drive it and the tank only holds 18.8 gallons, the savings for me between 85 and 93 would be less then $6.00 a tank. Compare that to my Cummins at 17 mpg it's chump change. If you concerned about saving $6.00 on a tank when you probably only fill up twice a month then maybe a Chevy Cobalt would be a wiser choice. They are available for less then $10K and can run E85.
