Old Mar 26, 2021 | 09:41 PM
Jack G's Avatar
Jack G
Default Re: Cleaning Head Lamps
Mikey 208, It looks like you have made an improvement in the clarity of your lenses. The 2 spots you circled were more than likely created by dwelling a rotary abrasive pad too long in one spot causing localized heat to be generated. As a result the plastic has melted in these areas. The only way to remove this condition is to once again apply the sequence of abrasive buffing to this area. It will take some work but you should be able to bring it back to look like the remainder of the lens. You could start out by using a more coarse grit abrasive in these 2 spots. This will initially remove more material, then you will need to gradually apply increasingly finer grit abrasives to bring back the clarity.
